Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coil spring rear suspension for 52 chevy coupe
Old 03-13-2009, 06:21 PM
327 / 350 hp's Avatar
327 / 350 hp 327 / 350 hp is offline
Rear coils on 52 Coupe
Originally Posted by AustinPhoenix
Hey guys,
Has anybody swapped rear ends with a factory coil over rear? Looking for a replacement that fits...or comes close to fitting.
Maybe I should swap to an open drive rear and then convert to coil overs? What do you all think?
Thanks!
Hi austin i have a full chassis swap on my 52 coupe. 72 chev chassis, that is wider by 2 in" ,but vette rims fit in wheel wells. You will loose the torque tube drive (a good thing) Hope you can weld & fab. GOOD LUCK jim
