coil spring spacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2005, 05:24 PM
bct bct is offline
coil spring spacer
I would like to raise the front of my 55 Chevy about 1 inch. I have thought about installing 1 inch rubber spacers(the kind that go below the spring.) Would I be able to compress the spring enough with a spring compressor or do I have to remove the shock and drop the A arm? Thanks for your help.
Old 12-30-2005, 08:21 PM
Back in the day......when I wanted to raise my 55..I got a set of 62 Chevrolet 327/AC Impala springs....went up about 1 inch....wanted more...got a set for a 409 62 Chevrolet wagon....3 inches or more....
you have to drop the A arm...to get the coil spacers in...
Coil Spring Spacer Bill Ford Suspension - Brakes - Steering 4 06-06-2004 09:24 PM
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 09:39 AM
info on Moog coil spring 406chevelle Suspension - Brakes - Steering 0 04-22-2004 09:26 AM
Extra-High-Lift coil spring for 72 chevelle 406chevelle Suspension - Brakes - Steering 5 04-03-2004 05:00 AM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 07:36 AM
