Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - coil spring spacers
  #16 (permalink)
Old 07-18-2010, 04:17 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
I have found on Ebay several sellers of a new set of aluminum spacers like the rubber donut you have shown, goes on the end of a spring, and have seen them in use, they work fine. I've used the rubber in the past, on top of the spring and this works fine also.
Never tried the rubber donut between two coils, that should make the spring stiffer rate but not give as much added height installed that way.
