Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - coil spring spacers
  #18 (permalink)
Old 07-19-2010, 06:28 PM
kidashley25 kidashley25 is offline
New Member
Originally Posted by APalusky
Are coil spring spacers ok to use?? I need to raise my front suspension by about 1". Mr. Gasket has them.. Thanks Al
It will just make it a lot stiffer and you will feel just about every little bump on the road. It will also give you more ground clearance in the back. You would be better off getting ac delco struts and ac delco coil springs . Unless you don't have the money get the spacers, better than bottoming out.
