coil spring spacers - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-18-2010, 04:17 PM
ericnova72's Avatar
More for Less Racer
I have found on Ebay several sellers of a new set of aluminum spacers like the rubber donut you have shown, goes on the end of a spring, and have seen them in use, they work fine. I've used the rubber in the past, on top of the spring and this works fine also.
Never tried the rubber donut between two coils, that should make the spring stiffer rate but not give as much added height installed that way.
  #17 (permalink)
Old 07-18-2010, 04:24 PM
Last journal entry: comming along
Thanks.. I will look it up.. Al
  #18 (permalink)
Old 07-19-2010, 06:28 PM
New Member
Originally Posted by APalusky
Are coil spring spacers ok to use?? I need to raise my front suspension by about 1". Mr. Gasket has them.. Thanks Al
It will just make it a lot stiffer and you will feel just about every little bump on the road. It will also give you more ground clearance in the back. You would be better off getting ac delco struts and ac delco coil springs . Unless you don't have the money get the spacers, better than bottoming out.
  #19 (permalink)
Old 10-01-2010, 02:04 AM
New Member
it will just make it a lot stiffer and you will feel just about every little bump on the road. It will also give you more ground clearance in the back. You would be better off getting new struts and springs. Unless you don't have the money get the coil spring spacers, better than bottoming out.
  #20 (permalink)
Old 10-01-2010, 02:20 PM
Well I have the spacers in. It did raise the front almost 2". As far as the back goes.. I don't really see any difference. The front was lowered 2" to start with 2" drop spindles. I also cut a full loop out of the coil which droped it another 2". I didn't have the wheels and tires that I was going to be running on it when I lowered it the first time. Now it sits fine. I do have to raise the headder drop tube about 1 1/2" though.. Al
Coil spring mount and selection questions iceman36 Suspension - Brakes - Steering 8 05-20-2009 01:20 PM
Coil Spring holdup iceman36 Suspension - Brakes - Steering 2 05-16-2009 10:47 AM
Cutting A Front Coil Spring leejoy Suspension - Brakes - Steering 21 03-31-2009 04:40 AM
Extra-High-Lift coil spring for 72 chevelle 406chevelle Suspension - Brakes - Steering 5 04-03-2004 05:00 AM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 07:36 AM
