Please enter info on type of vehicle and what you are trying to accomplish. If you are talking about the front of a pickup and you are trying to lift it,then you can't find 3" because it isn't recommended.The 1 1/2" will probably be all the suspension can handle with out being bottomed out on the stops giving you no up travel and making it a very harsh ride.
I assume you have 4 bar with coil springs.Before I would buy anything I would park it on a level surface and measure the height. Then I would disconnect the shocks and lift it the proposed 3" and see if there will be any binding of suspension or steering parts.If that looks good I would go for it.I know it is a little different but on a Ford truck I just lowered the top spring and shock mounts 3",but I am set up to weld and fab just about anything. I don't know what your skill and tool level is.Good luck.
Chevy 3/4 ton truck springs in a Jeep Cherokee?
I thought the cherokee springs were like 18 inches long. Are the chevy's that long? I dont really like the idea of using springs older than the truck when im gonna be doing some off roading.
| Coil spring "extenders", "spacers", etc. | connoisseur | Suspension - Brakes - Steering | 20 | 01-20-2011 08:40 PM |
| coil spring spacers | APalusky | Suspension - Brakes - Steering | 19 | 10-01-2010 02:20 PM |
| Coil-Over Spring Rate | J-Garden | Suspension - Brakes - Steering | 12 | 12-20-2009 12:45 AM |
| Coil spring for 350 on a S10 | GMC1950 | Suspension - Brakes - Steering | 5 | 02-29-2008 10:29 AM |
| If I cut a coil spring | Bluepen | Suspension - Brakes - Steering | 2 | 06-01-2004 06:06 AM |
