coil spring stabilizers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2006, 12:23 PM
any tips on how to install these? the bolts arent long enough so i got longer ones but still having trouble.I tried jacking under the spring to compress it a bit but it isnt enough. is there an easy way or so I just have to wrestle with them?
http://www.jcwhitney.com/wcsstore/jc...b3c19833252ffc
Old 08-30-2006, 01:11 PM
i used a tool that looked similar to what you're installing. I rented it from Auto Zone. But be careful, those springs are DEADLY! Good luck guy. torinotroy
Old 09-02-2006, 06:02 AM
6426yy's Avatar
I used those on my Impala in high school and they suck, I wouldn't use them again. They always come loose and make a lot of racket. In any case if your set on using them in a manner to compress the spring, I've used a log chain wrapped around the frame and under a small floor jack, positioned under the lower A arm. Then pump up the jack and it compress's the spring.
Old 09-02-2006, 12:55 PM
I think they would be best installed by shoving them up the tail pipe as far as you can get them.
If you want to lower your car for cheap cut the springs. There are many good posts you can search for on cutting springs.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 09:39 AM
info on Moog coil spring 406chevelle Suspension - Brakes - Steering 0 04-22-2004 09:26 AM
Extra-High-Lift coil spring for 72 chevelle 406chevelle Suspension - Brakes - Steering 5 04-03-2004 05:00 AM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 07:36 AM
