I have just through that
I am sure that you found out, but the close coils is on the top, and the bottom needs to set in a stop on the bottom. I had one on my 40 on the drivers side, I had to compress with tool and turn the spring 180 degree, I noticed that spring was really bowed. Now it is right and I put my shocks through the springs.
It is a dirty job, I have anger about no instructions to put a mustang II, they only let you get to guess. I am not an expert, but I would like to write a book with military specs, remove and install with illustrations of exploded of all parts in start to end. I hope you get it without doing it again. |
Turning coils
I finally got the left front a arms, I had to loosen the upper and lower ball joints and compress the spring enough for turn the spring on the stop. While it was compressed I had to release both ball joints, it isn't easy. I had to push the top hat and get a large screw driver to pry and slide the lower a arm and using a jack to keep in place, install the ball joints. Those tools to compress is a fun trying to get the tool parts out of the coil, you have to take at least a bolt from the finger and get it out, then you can get the left part.
Mostly, I have coils of the 375 lbs. Typical coils are less springs and or are easy. Thanks Ericnova72, now I am going back to the garage and finish the brakes, all the lines and routing to proportion valves. |
| Coil Spring holdup | iceman36 | Suspension - Brakes - Steering | 2 | 05-16-2009 10:47 AM |
| coil spring compressor(pic) | montea | Suspension - Brakes - Steering | 3 | 04-09-2007 11:47 PM |
| coil overs to replace leaf spring? | PairsNPaint | Suspension - Brakes - Steering | 3 | 12-03-2006 10:28 PM |
| coil spring spacer | bct | Suspension - Brakes - Steering | 1 | 12-30-2005 08:21 PM |
| front end popping | maddmaxx | Suspension - Brakes - Steering | 4 | 11-15-2003 08:24 PM |
