coil springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2008, 03:49 PM
cosmictbird's Avatar
good times!
Last journal entry: 64 thunderbird
coil springs
i removed the front coil springs on my 64 thunderbird, and the years of grime where all there. they cleaned up very fast and easy with a wire wheel brush. can i put any type of topcoat or finish on them now? my engine block is ford blue and i used an engine paint for that. can i match the springs up to that or will the finish all crack when i compress the spring back into the suspension system? what can i do or what do you suggest?
Old 07-15-2008, 08:31 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Yes you can do that just fine, the spring compressing tool might leave marks but probably would not be noticed, with one except the builder you, will know, if can you live with that, then it is a go..
I have used Rust-Oleum black for springs and it held up very well.
Old 07-15-2008, 09:41 PM
ceh383's Avatar
'51 Chevy 3100
Yeah, you can paint them. You have 44 year old springs, they do get weaker with age. I'd seriously consider new springs, it's a lot of work just to put the old sagging springs back in.....
Old 07-18-2008, 07:00 PM
onebadmerc's Avatar
I need a bucket of arc sparks
I would spray them with a black tinted epoxy.
Old 07-19-2008, 06:45 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I agree...springs that age are bound to be fatigued...I believe I would replace them.
coil vs. leaf springs davetc Suspension - Brakes - Steering 11 11-22-2012 02:17 PM
Hypothetical question about coil springs ckucia Suspension - Brakes - Steering 2 09-21-2006 12:06 PM
Chevelle Coil Springs projectjohn Suspension - Brakes - Steering 4 07-30-2006 07:09 PM
Front coil springs too long. hrussel Suspension - Brakes - Steering 3 07-23-2004 08:36 PM
Front coil springs too long. hrussel Suspension - Brakes - Steering 7 07-05-2004 09:23 AM
