Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coil Springs
Thread: Coil Springs
Old 11-10-2012, 07:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by shepardj View Post
I just received some new coil springs. One end of the coil is flattened out and on the other end the coil is just cut off at a given coil length. Which is the top and which is the bottom when installed ?
Obviously if there is a spring seat, look to see if it has a place for the uncut end to sit. If there's no spring seat it doesn't matter which way you install it unless there appears to be a fitment issue caused by the uncut end. In that case use a disc sander to smooth the end.
