Coil Springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2012, 09:27 PM
Coil Springs
I just received some new coil springs. One end of the coil is flattened out and on the other end the coil is just cut off at a given coil length. Which is the top and which is the bottom when installed ?
Old 11-10-2012, 07:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Obviously if there is a spring seat, look to see if it has a place for the uncut end to sit. If there's no spring seat it doesn't matter which way you install it unless there appears to be a fitment issue caused by the uncut end. In that case use a disc sander to smooth the end.
Old 11-10-2012, 07:48 AM
poncho62's Avatar
Wiki Edits: 5
The spring seat is usually built into the lower "A" frame....of a GM anyways.....We are talking about front springs, right?
Old 11-10-2012, 08:06 PM
Cape Cod Bob's Avatar
You may also need a rubber isolation for the top of the spring. On the MII front springs the flattened end is the top and the cut end fits into a slot on the lower A arm. Isolation pad goes on top in the tower.
81 c10 front coil springs swap for s-10 springs campracing Suspension - Brakes - Steering 3 10-05-2009 04:51 PM
coil springs Rons1stRod Suspension - Brakes - Steering 2 02-06-2007 10:08 AM
Coil Springs DoubleVision Suspension - Brakes - Steering 4 06-21-2005 04:04 PM
81 T/A Coil Springs T/A Toyz Suspension - Brakes - Steering 0 03-18-2005 12:10 PM
coil springs nick79camaro Suspension - Brakes - Steering 3 09-28-2004 02:48 PM
