Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - coil vs. leaf springs
Old 11-22-2012, 06:49 AM
gearheadslife gearheadslife is offline
Banned
Originally Posted by GRITTY454 View Post
I have a 72c10 with trailing arms and I'm looking for insite on how to make it hook up better. Sbc, turbo 400, stock gears, limited slip, non posi. (next thing on the list-posi) or am I wasting my time trying to get it to hook without posi.
posi would help..
they make shock brackets that put the shocks straight up and down..
helps alot.. a simple air bag inside the pass side coil to preload the rear helps.. with hooking up.. but not ride on the street..
pinion angle.. trucks that are lowered.. change this.. and i needs to be fixed.. (they make shims)
getting a full width track bar to replace the half lenth stocker..
I'd start with a posi.. then look into the other stuff..
The Following User Says Thank You to gearheadslife For This Useful Post:
GRITTY454 (11-22-2012)
