coil vs. leaf springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2005, 11:22 PM
i have a 64 chevy truck c20. it has a stock rear end with coil springs. i am going to replace the rear end with a 14 bolt. this is a daily driver, work truck. would it be better to change the coil springs to leaf? anybody have any pros and cons for each?
Old 12-10-2005, 05:55 AM
Bumpstick's Avatar
Hammer and a torch
IMPO... The trailing arm setup that Chevy uses on those trucks up through 1972 (some not all) is one of the best setups for racing or ride... A leaf spring is designed to work off two things both flex and friction... With time and age both the flex and friction change because of weight and corrosion inbetween the leafs... This causes it to ride rougher than normal and or sag... We used to actually put oil on the leaf springs of our trucks and shortly there after they would start to ride better...
Back to the trailing arm suspension... They are basicly a ladder bar and with different springs shocks can be made to really hook up better and ride smoother... Mainly just depends on what your going to do with it...? (coil is for ride and hookup while leaf is more for load carrying)
Old 12-10-2005, 07:33 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
I swapped a 14-bolt into a 66 bonneville and I had the axle modified to accept trailing arms and coils. I'm not a fan of leaf springs. They are simple and unimaginative and the very flexible coupling they create is all that's holding it to the vehicle. In low-power applications or where ride isn't a priority, leaves are fine.
Keep in mind, retrofitting leaves isn't as easy as it seems. Getting the proper driveline angle isn't quite as simple under load as you think when engineering your mounts.
I agree with Bumpstick. That twin arm setup used for years is great.
Old 12-10-2005, 08:43 PM
thanks guys.... i think i will keep the coil spring setup. you have me convinced!!
Old 12-11-2005, 11:15 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Most people don't realize that the late 60s Chevy pickup trailing arm design is what the super speedway NASCAR cars used for years...
Old 12-11-2005, 07:18 PM
Don Meyer's Avatar
If you are wanting to soften the ride you can go to a softer, but longer coil. Call Eaton spring.
Don
Old 12-11-2005, 08:11 PM
Bumpstick's Avatar
Hammer and a torch
And still do...!
Old 11-21-2012, 08:53 PM
I have a 72c10 with trailing arms and I'm looking for insite on how to make it hook up better. Sbc, turbo 400, stock gears, limited slip, non posi. (next thing on the list-posi) or am I wasting my time trying to get it to hook without posi.
Old 11-22-2012, 05:49 AM
gearheadslife's Avatar
MentalMuffinMan
posi would help..
they make shock brackets that put the shocks straight up and down..
helps alot.. a simple air bag inside the pass side coil to preload the rear helps.. with hooking up.. but not ride on the street..
pinion angle.. trucks that are lowered.. change this.. and i needs to be fixed.. (they make shims)
getting a full width track bar to replace the half lenth stocker..
I'd start with a posi.. then look into the other stuff..
The Following User Says Thank You to gearheadslife For This Useful Post:
GRITTY454 (11-22-2012)
Old 11-22-2012, 05:52 AM
MentalMuffinMan
I'd check to see if you really have a c-20.. look at the long arms,, there should be a flat plate riveted or welded to the bottom of them and go the whole lenth of the bar..
Old 11-22-2012, 05:59 AM
Wiki Edits: 27
older than dirt ?
Gm used the trailing arms. on Oldsmobile before they did on trucks. In the 50's we built a 36 chevy coupe using a 49 olds donor, engine, trans, rear end and the trailing arms. and we used both the olds and chevy shock absorbers at the rear . later the swap with a 31 chrysler roadster. and nobody ever beat us off the line , or was close at the other end either !
The Following User Says Thank You to timothale For This Useful Post:
Old 11-22-2012, 01:17 PM
Trailing arms
already posted. Thanks
Last edited by GRITTY454; 11-22-2012 at 01:23 PM. Reason: already posted and received a reply
rear leaf springs HD chopped pickup Transmission - Rearend 2 11-05-2005 01:31 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 05:45 AM
leaf or coil friend Hotrodders' Lounge 2 10-10-2004 06:45 PM
Converting coil springs to leaf on a 9" BillyBob1950 Transmission - Rearend 9 04-25-2003 04:27 PM
