coil wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2010, 04:51 PM
coil wire
1969 G.T.O. new engine wire harness 400 engine wire from termenal to coil is it 10 gauge ? it calls fore a black wire with pink stripe no such wire on old harness or new their is a solid pink 10 gauge wire on the new one or can i run a wire from the + coil to the fusebox and what amp of fuse?
Old 12-05-2010, 06:06 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I can not tell you the wire color, for the coil, however I can tell you how it works in the circuit so you could wire it and have it operate as it should.
The + terminal on the coil gets juice when the key is on only. Then off key off, also off with the key in the accessory mode. Get a meter or a test light and probe the wire or wires you have there and see if the voltage comes and goes as described. I do not believe it will run through the fuse block, more likely a direct connect to the ignition switch.
Old 12-05-2010, 09:48 AM
sqzbox's Avatar
My pipes are my music
I would wire it so the coil doesn't get juice when in ACC key posistion if your running a point system.
Cruise Control Compatibility with LED's? cboy Electrical 44 10-01-2010 01:08 PM
hei distributor coil wire bigvan98 Electrical 1 06-20-2007 10:57 PM
Coil Wire Colours PAS55 Electrical 3 05-19-2006 08:10 PM
Postive ground but negative coil, strange one Nightfire Electrical 21 04-19-2006 06:20 PM
Elec. fuel pump relay needed? upstand2 Electrical 4 05-10-2005 06:21 AM
