coil wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2011, 09:19 AM
coil wires
what wires go to the coil on a t-bucket?
I have the points distributor with the kill switch and push button start.
All i have ran to coil so far is red wire from distributor to + side and
black wire to ground on the frame. I was told kill switch should go to +
side of coil and red from distributor to - side of coil. I'm getting so
confused trying to figure it out for myself and listening to parts counter
people.
Old 10-24-2011, 09:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
people.
The "-" side of the coil connects to the wire from the distributor. The "+" side of the coil hooks to the power. During start up you want full battery current, while the engine is running you want to reduce the current (on most points-type coils, or if using a stock coil) by using a ballast resistor or resistor wire.
This can be done several ways. If you're wiring from scratch, I'd use a Ford-type fender well-mounted solenoid.
Old 10-24-2011, 03:38 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The the "kill" switch is really just an on/off switch. In the ON position the + circuit is completed to the coil. The on/off switch also provides power to the start button.
As stated, a point type distributor/coil will need a resistance in the + circuit to the coil.
GM provides a terminal "S" on the starter to provide full voltage during cranking.
A solenoid is needed if no "S" terminal is provided.
vicrod
coil wires need help s22tshortt Electrical 1 09-27-2010 04:15 PM
coil wires need help s22tshortt Introduce Yourself 1 09-26-2010 07:27 PM
coil wires? help me 52chevy3800 Introduce Yourself 1 02-15-2005 08:32 AM
Coil wires on '70 Chevelle? Seon Electrical 2 06-29-2003 07:36 AM
coil wires on a slant six? Rodder318 Engine 0 02-24-2003 11:01 AM
