Coilover shock spring length - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2014, 10:29 AM
1971BB427's Avatar
I just received my new QA1 coilover shocks and springs for the back of my old Austin gasser. Ordered them from Speedway, and the QA1 requirements said a 2.5"x8" spring, so that's what I ordered. The box is marked as 8", but the measured length is 10". So this brings up my question. Is this correct that a 8" spring would be 10" long? And if this is true, then the only way to get these assembled will be to back all the adjustment out, and then compress them to assemble. QA1 instructions don't mention compressing the springs, and details say to assemble the springs, and then turn the adjuster nuts up 1/3 of the threads for preload.
Either I'm missing something, or these springs are incorrectly boxed?
Old 01-18-2014, 11:14 AM
evolvo's Avatar
8" springs should be 8" long. Call supplier and confirm.
Old 01-18-2014, 12:13 PM
1971BB427's Avatar
Thanks. I have to wait for Monday, as by the time I got them yesterday afternoon it was too late to call. I sure was anxious to assemble and install them, but don't want to do so until I contact them. Hope I don't have to wait for more return/exchange time, but might have to.
Old 01-18-2014, 12:48 PM
They may go by "installed height" but I can't confirm or deny that [do I sound like a politician ???]
dave
Old 01-18-2014, 02:55 PM
1971BB427's Avatar
dave
That was my question to myself, but the spec says, "free length", so I would guess free means uninstalled.
Old 01-19-2014, 09:41 AM
S10xGN's Avatar
Gotta love a turbo!
The correct spring should be a tight fit when hand assembling. You really have to press a bit to get the threads on the lower spring seat started. If you're 2" off, you'll know it for sure...
Russ
Old 01-19-2014, 12:38 PM
1971BB427's Avatar
Russ
Yeah, measuring the distance between spring retainer and threaded adjusters, I get just over 8", so a 8" spring would drop over, and slightly compress to get the retainer collar on with threaded adjuster backed off. No way I'd get these on without my coil spring compressor.
Old 01-19-2014, 01:14 PM
life is a temporary assignment
the last five or more set's of QA1's wasn't tight at all to put the springs on the shock's.. I use 14'' on every car..I can go check the lenghts on the springs if you want me too..
Now the cheaper ones speedway sell's are thight to install.. I quite useing them..
Old 01-19-2014, 01:20 PM
1971BB427's Avatar
That describes what the instructions say. No mention of having to even slightly compress the springs to install them on the shocks.
Old 01-19-2014, 01:31 PM
The ones I been useing doesn't need compressing to install at all.. I'm going to take one apart to check the lenght.. I'll be back with that in five Mins..
Old 01-19-2014, 01:38 PM
This is the 14'' at ride height from speedway,, It has a 12'' spring and this is the room it has before thighting up the nuts..(the nut's are all the way down)
Old 01-19-2014, 02:07 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Free Height vs. Installed Height:
http://www.moogproblemsolver.com/moo...rings_Spec.pdf
Old 01-20-2014, 08:48 AM
1971BB427's Avatar
Thanks for the help guys!
Just got off the phone with Speedway. They were great, and went the extra distance to make things right. Even though these were closeout garage sale springs that said no returns, they not only are taking them back, but are replacing them with a more expensive spring for the same price. Sending the new coils out today, and I'll send these back when they email the RTA slip for UPS.
The Following User Says Thank You to 1971BB427 For This Useful Post:
NEW INTERIORS (01-21-2014)
Old 01-21-2014, 09:07 AM
Speedway is very good to you when it come's to them kind of things..Great bunch of guy's over there..
Old 01-21-2014, 09:12 AM
1971BB427's Avatar
I was a little concerned, since it said "No Returns on garage sale items", but the fact they were mismarked I hoped would change that. They were great, and very accommodating to make it right. Glad I checked all the optional springs before contacting them though, as they first said they had nothing in stock. Once I gave part numbers for 2-3 other 8" springs they just looked until they found one in stock and said they'd upgrade to it free.
Coilover vs coil spring front end 57fordft Suspension - Brakes - Steering 1 05-07-2009 09:12 AM
coilover vs. standard spring Rufus_2 Suspension - Brakes - Steering 12 02-09-2007 04:18 AM
Coilover shock adjustment mackster Introduce Yourself 1 07-03-2006 10:03 AM
shock mounts out of alignment and shock length? pcoghlan Suspension - Brakes - Steering 4 05-08-2006 06:22 AM
Incorret Coilover Spring Rate? GLN305 Suspension - Brakes - Steering 5 10-09-2003 02:50 AM
