Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coilovers
Thread: Coilovers
Old 06-18-2003, 07:32 AM
Hellzapoppin's Avatar
Hellzapoppin Hellzapoppin is offline
I've just bought a 4 bar coilover kit for my F1 pickup but after reading the installation instructions I'm totally confused about how to set the pinion angle. The book says that the axle brackets should be welded at 90 degrees (straight up and down) and the pinion angle set by adjusting the length of the 4 bars but (this is the confusing bit) if the coilovers are fixed to the chassis with bolts running front to back it's physically impossible for the angles to change or am I missing something I would have thought
that the angle of the brackets to the axle would be the way to set the angle. Any help would be appreciated
