Coils - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2004, 09:50 PM
Coils
Do I have to use a msd coil with my billet msd distributor? The msd coil is about twice as much as an accel one so whats the deal is a coil a coil?
Old 04-16-2004, 12:14 AM
Pony's Avatar
NO. It's usually easier due to the mfgs wiring and plugs matching but any good high output performance coil will work. If your using a multi strike box like a MSD unit it's best to use the larger finned heat sinked coils to deal with the extra heat generated by the extra coil cycles. I wanted to go electronic with my 74 Vet but wanted to keep the mechanical tach drive distributor so I used a Mallory conversion kit, Crane epoxy finned hi po coil, MSD 6al Box, MSD cap & rotor, Taylor 8mm wires and Accell plugs. The motor doesn't know the difference and is happy.
Old 04-16-2004, 11:39 AM
I guess that I should have been more descriptive in my original thread because I'm using a msd ready to run distributor. I'm not sure if that makes a difference between a "box type" unit or not.
Old 04-16-2004, 01:10 PM
Pony's Avatar
Any 45/50,000 output coil will work. I would prefer using the MSD just for ease of instillation but I'm a happy MSD customer. The box units are an add ons that are not necessary for normal operation. If you use a Blaster2 coil and later want to use a MSD 6 series type box the blaster would still work fine. The big finned coils are for higher output racing type ignition systems. Sorry for any confusion that I may have created.
