cold air for a Fat CAt ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2006, 09:44 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
hey everyone... well the car i think could benefit from cold air. so that being said what would be the best way to go about this? I have a carb so it has to attach to that.. and i would like to get this symmetrical so two tunnels . I do have 4 lights and i could cut one per side but.. i rather not.. and im sure i should use filters but what type could i use the cone type or use flat ? Any and all suggestions would be greatly appreciated! Maybe theres a system i could buy for this or another one i could i modify ....
thanks everyone
'70' Cougar
Old 08-06-2006, 10:09 PM
How about a carb-mounted two-snorkel air cleaner housing like the carbed HO Mustang unit (or a home-built facsimile) with tubes running to a source of outside air? Or, if your bank account's healthier than mine, check out www.ramairbox.com .
Old 08-06-2006, 10:30 PM
Steve karch's Avatar
I use the Ram Air Box. Cold/ram air is defintely the only way to go. I pick up air under the bumper using scoops for heater ducts.
Old 08-07-2006, 08:39 PM
darn rights doggy.... sweet.. i totally want that... and its gotta be the dual setup i looked at the sight.. and its defiantly what i want... but ordering it looks complicated... i don't know exactly the size i want..
If anyone had time ... i have a 670 Holley 4 barrel double pumper street avenger on a 70 cougar with a Cleavland stock manifold...and as well i would probably need the drop plate or what ever its called to make it a touch lower.... and maybe like 14 inches across? All i guess i want is the box set up i don't need the tubes and fittings .. i can at least do that much
Anyways thanks i cant wait till i eventualy get this setup it'll be so BOSS!
thanks
bill
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
air filter location. yus Engine 1 08-04-2006 08:28 PM
plugs fouling, cat worries, and more - help? joe99 Engine 9 01-23-2004 07:16 PM
fabricating a cold air induction system? stfinney Engine 5 12-12-2002 09:37 PM
cold air induction solowookie Engine 17 03-28-2002 08:37 AM
