cold air induction - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2002, 09:34 PM
Lightbulb cold air induction
ok guys... here's my brainstorm, and I'm wondering how hard it would be to accomplish, and if it would be practical...
I'm considering turning the upper cowl on my 1950 chevy truck into cold air induction. it would look stock, and I'm thinking would be a great idea.
Old 02-21-2002, 09:52 PM
Post
Well it would take a lot of work to do and there is lots of easyer ways to do it.But it would really be cool and as soon as I read your post I had it figured out in my head.I would try to figure out how to push a little juice with it.No sense having all that air going in without something to go with it. Of course I am a screwed up old racer and my mind thinks nothing but HP after you get it started. ROY
[ February 21, 2002: Message edited by: Roy Newton- exprotech ]</p>
Old 02-21-2002, 10:05 PM
Post
well just an idea I kinda got kicken around, but if I went that route I'd probably go with a 400 stroker with the 6" rods. I'd have <a href="http://www.asrengines.com" target="_blank">asrengines</a> build it for me. I'd want the engine built for torque and low RPM's, but I've heard real good thing about that engine...
my other engine choice would be a 350 ramjet, but I'm not sure how I'd fabricate the cold aid induction with that cuz it would seem better to come from the front for that application.
Old 02-22-2002, 05:09 AM
1meancuda's Avatar
At a loss for words
Post
I once saw a guy running drag races (I think the car was a Buick GS. It was a while ago so I can't really remember the car ) Anyways, that's not the story. He had hooked up a ram air system from by his head lights and then up to his air cleaner. Know what he was using for this? Dryer ducting!!! A little imagination can really take your vehicle a long ways!
Old 02-22-2002, 10:05 AM
Post
I'm kinda thinkin a 400 stroker with a manual injection system <a href="http://hilborninjection.com/images/tn-AJ1MD.jpg" target="_blank">such as this</a> with the cold air induction.
I'd get fuel injection, a great performane fuel injected engine, and something a bit more trick.
Old 02-22-2002, 10:41 AM
Cool
If you Check out this website:
http://www.ramairbox.com/
They may have the answer, they have a truck on their with a cowl induction type set up like you are talking about. I do not think it would be super tough to accomplish. just a little fabricating.
Old 02-22-2002, 01:03 PM
Post
I think its a good idea also, any time you can introduce more cold air to your engine will always be good. It may take a little engineering and fabricating . But it should be worth the effort.
Old 02-22-2002, 05:26 PM
Steve karch's Avatar
Post
I put a Ram Air Box in my Beaumont. I use aluminum dryer ducting and modified heater ducts for air scoops under the front bumper. Its a good system and so far the best bang for the buck. Its great in hot weather as the engine is alway breathing cooler air.
Old 02-22-2002, 07:17 PM
Paco's Avatar
Post
check out a '70 Chevelle SS 396 or 454, they could be had with factory cowl induction, if I remember correctly, it was a vacuum operated door on the cowl that opened towards the windshield when you stood on it. Been too many years to remember the specifics, but I do know where a couple are if you need more info.
Old 02-23-2002, 06:14 PM
New Member
Lightbulb
I can't help but comment on Paco's post - my Sister's Husband owned a 70 Chevelle 454 w/Cowl Induction - she took great pleasure in giving rides and "watch the little door pop open when I stomp on it" - Don couldn't belive how fast his rear tires wore out!! Yes it was vacuumn operated.
If you set up for induction don't forget to allow for any water that finds it's way in to drain out of the air cleaner - I swamped out my V8 powered Pinto many moons ago (hood scoop ducted into air cleaner/rain storm/no drain/bad combo!)
Old 02-23-2002, 07:59 PM
Post
OK let me ask a stupid question...
in this application how would I build a drain into it? I'm assuming that everything is built to flow into the top of the carberator or mechanical injectors (etc.) so where would I put a drain?
how is a drain typically worked into an application like this?
Old 02-24-2002, 06:34 AM
Talking
I would use two drains one in the cowl box and another in the box that attaches to your carb or injectors. You would need to design both with a low spot that the water would drain to and from there to the outside of the car.1/2 in.rubber hose would probably work fine.If you can figure out how to build the rest of the system the drains would be the easy part lol. :p
Old 02-24-2002, 08:41 AM
Post
LOL - yea I'm sure your right about that. I'm able to pictures the rest in my head, but for some reason the drains were escaping me.
Old 02-24-2002, 02:19 PM
New Member
Post
If I remember correctly the cowl vent already has a drain to it - at least the 51 Chevy 3/4 I owned years ago had one!
Old 03-06-2002, 01:57 PM
slomotion's Avatar
Post
I think I would be inclined to incorporate a baffle with the first drain just up-stream of it. The rain theoretically wouldn't be able to react as quick as the air and get "stuck" whereas the air would pass over it. I don't think I would want the water to get as far as my air-cleaner.
« Engine | olds »
