Is a cold air intake really worth the money? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2009, 10:50 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Ever since I bought my Mustang I've wanted to do a few minor things to increase the horsepower but have always been hesitant to buy a cold air intake and a programmer because I was never really sure if they were going to make all that much of a difference. Last night I finally decided to break down and buy a Roush cold air intake and a Hypertech programmer. Hypertech advertises 4-5hp increases through most of the RPM range and 8hp at the factory peak, and it has programs for regular and premium fuels. I trusted their claim because the numbers didn't seem outrageous like some I have seen. For example: A friend of mine wants an Edge programmer for his F-150 because he saw an advertisement that said the programmer by itself would give him 30hp over stock, which is total bunk if you ask me.
Anyway, I'm hoping for a ballpark increase of about 20hp between the intake and the programmer, which would bring output up to 320 or so. Is this a reasonable assumption or am I spending money for nothing here? The car is a 2007 Mustang GT.
Old 11-05-2009, 12:18 PM
sqzbox's Avatar
My pipes are my music
Don't forget the mileage increase too.
454headache's Avatar
20 hp over stock from a V8 seems reasonable to me.
Old 11-05-2009, 12:27 PM
sqzbox's Avatar
Everybody want's big HP gains like 30-50hp out of one bolt on, whatever. But, small gain's add up too. Larger injectors, re-programing, cold air intake, exaust, underdrive pulley's, and things like that.
Old 11-05-2009, 12:34 PM
Banned
Its a cheap and easy power gain, BUT there are gains that cost the same amount for parts, but are a lot more labor intensive that produce more power...
Old 11-05-2009, 12:47 PM
Blazin72's Avatar
Wiki Edits: 19
Though any increase in mileage is always nice, I'm not too concerned with it. I can't imagine it would be too dramatic anyway.
I thought about pulleys but I am not too keen on underdriving components.
The Hypertech web site did show the programmer also increased power up to about 6200 rpm. It's currently limited to 6000 right now and it seems to be pretty common to raise the rev limiter to about 6250 without any issues.
Old 11-05-2009, 01:32 PM
add a "." before the 7%
Generally feeding cold air to the intake increases power by about .7% for every 10 degree F drop in temp from the temperature of the air available from under the hood.
The power programmers take advantage of the fact that the factory has to meet Federal emissions for a period of 100,000 miles without maintenance. So the factories make a management system that is very conservative such that the engine will age out without exceeding pollutant levels till above 100,000 miles. The reprogrammed power packages eat into the factory long term emissions spec for near term power increases. This adds power but at the cost of the vehicle probably not being able to pass emissions beyond 50,000 miles without some major work to correct the effects of aging wear and its affect on emissions.
Bogie
Old 11-05-2009, 04:44 PM
ericnova72's Avatar
More for Less Racer
Bogie, is that 7% per 10 degree drop a miss-print?? Figure I've always heard is 1% per 10 degree drop.
7% would be fabulous, drop the air temp 50 on a 500 hp engine and I'm going to get 175 extra hp?? I don't think so
Old 11-05-2009, 05:38 PM
cold air
Cooler air is ALWAYS better for performance. If you can get some "ramming-effect" thats even better. Once you get more cooler air IN...you also need to get more exhaust out easier too! Thats were you get a real"seat-of-the-pants" power increase. Headers and larger pipes and free-flow cats and muffs......the list just goes on-and-on!
I have heard it is better to do most all your mods and THEN have a custom chip burnt for the computer. That way the computer can take advantage of all the changes you made.
Sounds good to me.
6sally6
Old 11-05-2009, 05:44 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Is this a current Mustang?
If so I would spend some time researching. There are likely a magazine or two who have done some before and after dyno testing of bolt ons.
Always beware of the part makers dyno results, after all they are trying to sell parts.
Old 11-05-2009, 06:06 PM
Blazin72's Avatar
Wiki Edits: 19
1ownerT, the car is a 2007 Mustang GT. I understand what you are saying. I am inclined to think the Hypertech numbers are a little more in line with a real world increase than the results my buddy found for his F-150. A magazine article is actually what gave me the idea to go with the Hypertech, they didnt have any hard dyno results but did have favorable things to say about it.
6sally6, the newer generation Mustangs actually have a very good exhaust (including the cats) and replacing the cats or replumbing the exhaust isn't going to do much for a nearly stock engine. New mufflers are in the works once I find something that I think sounds good. The factory exhaust manifolds aren't too shabby either. Ford spent a lot of time on the exhaust of these cars. Mine does have an X-pipe though.
Old 11-05-2009, 06:41 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
I can get behind the cold air intake - depending on how it is done. Are there any modifications you can perform on the factory piece?
Not familiar with the Mustang plumbing but on a lot of cars there are baffles and such that can be removed - they're in place to quieten the induction noise.
You may also be able to plumb something of your own.
I've seen some so-called 'cold air induction' setups from the aftermarket that give you a large cone filter right behind the rad. How cold is that?
Old 11-05-2009, 08:35 PM
sqzbox's Avatar
I'll give you an example of cold air intake alone. I had a 73 lemans with a 455 in it and switched from an open element air cleaner to a closed type with 2 snorkel's. I ran a section of aluminum clothes dryer duct from each snorkel to either side of the radiator through to just behind the grill. It made enough difference that I could feel it the seat of the pant's especially when the sun went down. Engines like cool dense air and just with the cold air intake, there will be a performance increase alone. Adding a performance program will add to that. So my answer to your question is yes! Used with a K&N type filter also add's power with less restriction of air flow.
Old 11-05-2009, 10:16 PM
Wiki Edits: 31
save your money. buy a supercharger
Old 11-05-2009, 10:37 PM
Blazin72's Avatar
Wiki Edits: 19
Thats a lot of saving. Superchargers for those cars are $5000. One is on the list though.
Suggestions for air intake setup from Spectre or other? Yes, no? bubbahotep Engine 4 09-04-2008 12:53 PM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
hot air intake fiscus Engine 2 11-07-2005 02:19 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
stealth cool air intake system for 55 Bel Air Berliner Bel Air Engine 9 11-30-2004 03:32 PM
