Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cold Air vs Ram Air
Old 04-17-2009, 09:29 AM
joe_padavano joe_padavano is offline
Several sources (such as the Doug Roe Qjet book) indicate that there's a one HP increase for every 7-10 degree drop in inlet air temp. Unfortunately, most aftermarket "cold air" packages for newer cars discard the factory ducting that really does pull in outside air and replaces it with a cone filter under the hood sucking hot air from behind the radiator. DOH!
