In most cases, ram air is used incorrectly, it is hard to get air pressure by scooping air it in and then directing it through the air intake. The only way to get good ram air pressure is by directing the air straight to the intake. When you get twists and turns in your hose, it gets hard for the air to compress. So unless your hose is short and simple and your scoop is positioned right, then yes, ram air is pretty much a myth.
