Cold Air vs Ram Air - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Cold air vs Ram air
Cold Air 17 60.71%
Ram Air 11 39.29%
Voters: 28. You may not vote on this poll
Old 04-17-2009, 08:18 AM
83SILVRADO's Avatar
GROUND POUNDER
Cold Air vs Ram Air
Which is better cold air or ram air. which would be better on a 98 camaro z28 ls1? thanks for any help.
Old 04-17-2009, 08:26 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Ram air is a myth. There is no such thing as "ram" air until about 200 mph at which point the scoop becomes more of a drag than the 1psi of pressure adds to the power. cold air is good, ram air is just cold air that is moving.
Ram Air has been tested a few thousand times at Bonneville. There is a constant balance happening between additional drag and additional power added from ram air... but these guys are travelling at 250 mph. At the 120 mph that you might see once every few months, there will be absolutely no benefit to ram air.
Old 04-17-2009, 08:29 AM
83SILVRADO's Avatar
GROUND POUNDER
haha thats what i said.
Several sources (such as the Doug Roe Qjet book) indicate that there's a one HP increase for every 7-10 degree drop in inlet air temp. Unfortunately, most aftermarket "cold air" packages for newer cars discard the factory ducting that really does pull in outside air and replaces it with a cone filter under the hood sucking hot air from behind the radiator. DOH!
Old 04-17-2009, 08:32 AM
curtis73's Avatar
Wiki Edits: 16
Right, Joe, which is a good case for ram air... not because it rams, but because it definitely gets cool air from outside the vehicle.
But don't call it ram air unless its a Pontiac muscle car
Old 04-17-2009, 08:34 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
Jackson when are you getting the camaro to put the cold air on plus we live in tight area we dont get up to speed for the ram air to really work.
Old 04-17-2009, 08:38 AM
83SILVRADO's Avatar
GROUND POUNDER
im getting the camaro in about 2 months probably. as soon as i can sell my truck... you should scrape some money together and buy it.
Old 04-17-2009, 08:39 AM
72fordlb's Avatar
I would love to buy it but i have a ford truck already. u should post a for sale add on here.
Old 04-17-2009, 08:42 AM
83SILVRADO's Avatar
GROUND POUNDER
yeah you have a ford. all the more reason to buy a chevy. haha
Old 04-17-2009, 08:51 AM
Banned
"ram air" is not a myth, and if applied corrctly will not increase resistance (it can actaully lower it).
However, most people don't know how to design or tune it, all things being equal though ram air is better than cold air.
Old 04-17-2009, 08:52 AM
72fordlb's Avatar
Ahahahahahah NO!
Old 04-17-2009, 09:00 AM
Banned
I'm going to refrain from starting a long pissing match over this, and just ay people should do a lot of reading and research if they wish to design an effective air intake system.
Old 04-17-2009, 09:26 AM
As an aerospace engineer, I can tell you that airflow management is a complex and difficult activity. You are correct in saying that it is possible to use dynamic pressure from vehicle movement to increase airflow to the engine. You are not correct in saying that it will not increase resistance, however. You will always have less drag by diverting the air around the body than ducting air into the body. Yes, NASA and the Air Force has been looking at and test flying boundary layer control systems for decades, but so far very little practical hardware has come from that. By definition, "ramming" the air into the engine requires you to slow it, which requires drag. Without the resistance, there is no increase in dynamic pressure.
Old 04-17-2009, 09:58 AM
Banned
And if the air is already benig ducted through the body?...
Old 04-17-2009, 10:19 AM
In most cases, ram air is used incorrectly, it is hard to get air pressure by scooping air it in and then directing it through the air intake. The only way to get good ram air pressure is by directing the air straight to the intake. When you get twists and turns in your hose, it gets hard for the air to compress. So unless your hose is short and simple and your scoop is positioned right, then yes, ram air is pretty much a myth.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
1969 GTO Ram Air IV Croz Engine 5 09-20-2006 06:37 PM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
anbody run this cold air system spinn Engine 6 05-08-2005 08:49 PM
Ram Air Intake - 67 Mustang hot rod jerry Engine 4 06-26-2003 04:38 PM
