cold galvanizing spray vs weld thru primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2009, 07:24 AM
If it is basicly the same as weld thru primer (95% zinc), can it be used as weld through primer? It's a heck of a lot cheaper.
Old 10-29-2009, 07:42 AM
Last journal entry: 50 Ply wagon
Cold galvinizing spray is meant to be used on metal to help prevent rust. Weld thru primer is meant to be used on bare metal that is to be welded and then protected to help prevent rust. If you use the galvinize spray and weld it it will just burn off.
Old 10-29-2009, 04:19 PM
colormecrazy's Avatar
Paintshop Dog
BTW... Get all that zinc off where you can before putting anything else on it. That stuf is ... IMO... made for places you can't get to with paint later. And it typically will keep your paint from sticking.
Old 11-07-2009, 07:13 AM
deadbodyman's Avatar
Wiki Edits: 11
I was a weld tru primer fanatic until my painter swore Rust-Oleum cold galvanizing compound was better and much cheaper....Well, I tried it and it works very well....Not only can you weld through it but you can paint the inside of rockers (for instance) before welding them together.I was impressed and use it at the shop all the time now.Its runs about 5.00 a can....I sprayed a scrape piece of unprimed metal and left it outside it didnt rust...use light coats it works great....I'd like to buy it by the gallon...
Old 11-11-2009, 08:37 PM
Make sure when using weld through primer you apply it but then right befor you weld scratch it off the imediate weld area or it will mess with the weld itself.
Old 11-12-2009, 05:39 AM
Wiki Edits: 11
I havent had that problem ,strait. The rustoleum stuff has so much metal in it it conducts electricity the welds come out pretty darn clean.I usually use epoxy primer on the high dollar work and use an aircraft rivit cleaner or a spot weld cutter to clean the area to be welded but that takes a lot of time. On used cars or collision work I just use the cold galvinizing compound and weld it up...I was very surprized how well it worked...and at 1/3 the price...
Old 11-12-2009, 05:49 AM
Last journal entry: Bringing home the 401 Nailhead
Sort of contradicts the "weld through" part of the statement. I haven't had a problem but I am not a professional welder.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Vertical Welding JohnBrayan Hotrodding Basics 12 10-18-2009 10:01 AM
Primer problem daz59 Body - Exterior 3 05-16-2008 06:10 PM
stick welding question powerrodsmike Garage - Tools 51 05-11-2008 11:01 PM
3M Weld Thru Primer cruzinTLT Body - Exterior 12 07-26-2006 01:46 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 01:28 AM
