Sounds completely normal to me, leave it alone if it's running well. Why is 2-3 minutes of warmup unusual/undesirable to you?
Outlawed tunes from outlawed pipes |
Cold natured..................
I know what you mean....some cars will start and idle perfectly right off the bat. My Pontiac is like that. I can get in it, turn the key and drive away.
My truck, however takes a minute or so before it runs decently. I guess it's all in the choke settings, but I just havn't been able to get it just right. Maybe, it's a slight vacuum leak that seals up once it warms up a bit.............
Ontario Rodders |
By the way, theres no choke on this carb
I just don't know what it is?? the only difference that I can tell you between this camaro and my last one is the license plate. Same exact setup 350/Edelbroke carb.
Different heads? Different cam?
Lobe sep is one of the "cold-natured" things you can't tune out with carb settings or timing. You can try and acheive some though. Your last carb probably ran too rich when warm at an idle? ever so slightly at least. |
| Too long of a cold idle | woundup | Introduce Yourself | 1 | 11-24-2004 04:42 PM |
| How cold is too cold to paint in a makeshift booth? | misteryu | Body - Exterior | 8 | 11-08-2004 05:56 PM |
| Very rough idle on cold start up? | TravisT | Engine | 8 | 03-20-2004 06:43 AM |
| olds 455: engine idles rough when started cold. | 98rocket | Engine | 5 | 05-09-2003 05:01 PM |
| Cold run/fuel enrichment for '94 Chev 350? | FlyB58 | Engine | 4 | 01-04-2003 07:54 AM |
