Cold start diffficulties - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 07:06 PM
juiced66malibu's Avatar
I have a big block Chevy motor in my 72 Fleetside truck. I Have a 750 Rochchester quadraject carb. I don't have an auto choke so I have butterflies open at all times.
Just recently, in the first morning start I have difficulties starting the truck so I changed the coil, spark plug wires and spark plug. Still the same problem. I advanced/retarded the distributor to ge the timing right but still no start. It is only when I spray (starting fluid) into the quadtrajet carb it starts and once the engines warms up, I can start it with no problems.
Any recommendations welcome. Thanks!
Old 07-11-2010, 08:20 PM
sqzbox's Avatar
My pipes are my music
Does pumping the gas peddel a few times before you crank the engine help any?
Old 07-11-2010, 09:19 PM
yes, I have pumped the gas pedal multiple times.
tomorrow, I am going to change the insert fuel filter in the quadrajet and do a fuel volume test (1 pint flow in 30 seconds).
If I still have problems, I will pull the carb and inspect the gaskets.
Old 07-11-2010, 09:39 PM
sqzbox's Avatar
That was going to be my next recommendation if pumping didn't help. You might want to check the accelerator pump also before you pull the carb. Remove the air cleaner and manually pump the linkage and check for the squirt from the accelerator nozzles. It's easier to check on the engine than off.
I've got a 600 holley on my 350 and in the summer time, one pump and it fires right off with no choke. That could very well be your problem being it fires up with a shot of starting fluid. Might try just a small prime with gas also.
Good luck.
Old 07-11-2010, 11:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds like you have the common problem to many Q-jets- a leaky fuel well(s).
There are wells that extend down to the bottom of the carb that are sealed w/either a soft metal plug or a disc w/the metal peened over the edge of the disc to seal the wells. If these leak, over time the fuel will drain, drip by drip, from the float bowl into the intake manifold where it will either evaporate or pool, depending on the engine temp and how fast the leak drips fuel.
This condition causes the engine to have to be cranked over until the pump fills the fuel bowl back up w/fuel. It's worst w/a mechanical fuel pump.
The "cure" is either sealing w/epoxy, re-peening (carefully) the seals, using the black foam seal piece that's included in carb kits or a combination of the above.
That all said, there's usually enough fuel left in the accelerator pump well to provide a couple squirts of fuel into the carb- which is usually enough to get the engine to start, or at least try. If you're getting a good accelerator pump squirt or three and the engine still doesn't even try to start, you have other problems.
Old 07-12-2010, 06:10 AM
sqzbox's Avatar
Thanks for the help on this Cobalt. I wasn't aware of the well seals but was thinking along the same lines as if there is no or weak pump shot that either the accelerator pump was shot or fuel is disappearing somewhere or a combination of both.
I think we've got him going in the right direction though.
Old 07-12-2010, 06:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The pencil is pointing to the main well plugs, the primary side can leak, too- just less likely. One of the primary wells can be seen in the bottom left of the photo:
The PRIMARY plugs also can be removed and the holes tapped for short 8-32 screws.
Old 07-12-2010, 07:11 AM
poncho62's Avatar
Wiki Edits: 5
Hook the choke up............
3800 cold start problem Rubberman2003 Engine 8 02-07-2012 02:53 AM
engine start fine when cold when HOT I have to wait about 1/2 hour amature Engine 15 09-05-2009 07:25 AM
crank no start meev182 Engine 7 06-17-2007 06:27 PM
hard cold start akm Engine 19 05-16-2004 10:46 PM
Very rough idle on cold start up? TravisT Engine 8 03-20-2004 06:43 AM
