Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cold Weather Painting
Old 10-30-2005, 08:54 AM
crashtech's Avatar
crashtech crashtech is offline
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
There was some discussion of painting in the cold in this thread. I think the consensus is that the metal should be kept above 55F during spraying and for as long as possible afterward, at least 48 hours. If you have a heat lamp you can use that too, moving it around the vehicle, but for a complete paint job it's probably just better to keep the heat on for a good long while!
