Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cold Weather Painting
Old 10-31-2005, 05:40 AM
adtkart adtkart is offline
Keep in mind that the metal temp is the important part. I will heat the garage and vehicle for a day or so before painting, and atleast a day after. It takes some time for the vehicle to warm up, if it is cold outside. If it is staying in the garage all of the time, the actual metal temp is likely not as low as the temp outside, unless the temp outside has been that low or lower for a long time.
