cold weather painting&needing help
Any tips for painting when its cold?I'm gonna re shoot my truck my building is 24x36 its a pole building has been seemed with osb&the inside has 1&1/2" thick foam board Ill be in the first half the roof isn't that high in the first half...the building is like a shed roof style what some may call a lean too or pitched.Ill be running my big torpedo heater on the other end facing away from where Ill be.Its well ventilated the temp outside will be around 50,
I know I need to have the metal on the truck warm any other things I should know?Also I just painted this truck this summer with a smaller compressor but got a lot of spots that looked like real shiny orange peel I had a guy who use to paint back in the 80s look@ it&he said I went on too thick since then I've practiced so hopefully Ill get this right.Ill shoot some test panels first.But what works better for you going fast or going slow?when I go fast I get crap results but when I go slow I get that nice smooth wet look but runs its a ss dark grey non metallic also if I want can I shoot clear over this?thanks
