Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
Old 11-25-2012, 08:06 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by cutthroatkid View Post
Trying to get it done as I may sell it after taxes to fund a dually cummins&I might wait till Monday to get the fast hardner if you think the med wont work if you say no then its no because everything you've told me in the past I have found was all true.As far as the mist coat..so pretty much just step back&do a light mist?I'm guessing a little lighter then if I'm trying to get rid of tiger striping on a panel is that right?Should I wait till its good&tacky till I lay my first coat afterwards?
First, I would not recommend using a hardner from one manufacturer and the paint from another. It might work...it might not, you don't know what chemicals are in one that may not be in the other, if you can't get a faster catalyst, stay with what you have.
Yes you are right, apply the mist coat as if you where trying to even out metallic's and let it get tacky before applying a heavier gloss coat.
Ray
