Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #22 (permalink)
Old 11-25-2012, 07:44 PM
mr4speed mr4speed is offline
I do quite a bit of the cold weather painting and you really should use the fastest reducer you can get for that paint. The one "good" thing I can say about painting in the cold is there are NO bugs. I don't care how well I seal everything off, there are always bugs landing somewhere on the work. Not so bad for the sealer or base, but your really in trouble when they start landing in the clear. So for that reason I try not to spray in the warmer months. And like I said before you really need to push the flash times longer in the cold than you would normally. Especially with a S/S paint, that will take longer to flash than a base coat would even in the cold weather. I don't know how long that particular brand calls for flash times, but I myself go double if not triple on those times, according to just how cold it may be.
The Following User Says Thank You to mr4speed For This Useful Post:
novafreek6872 (11-25-2012)
