Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #30 (permalink)
Old 11-26-2012, 02:46 AM
cutthroatkid's Avatar
cutthroatkid cutthroatkid is offline
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Hey there I was In the process off posting this but Ill paste it&add to it&it should give some more insite......
also before I forget..I had a brand new fiberglass hood I painted with the same gun same temp conditions etc the thing came fresh out the box&I just shot it as a test no prep work came out flawless with a nice gloss&could see my reflection..then I had a fender that I sanded to bare metal&that although of course you could still see the sand marks..didn't have the paint flaws The test hood I used I did only use 1 coat of primer&1 coat of paint.The single coat of paint leads me to believe it isn't solvent pop.I'm leaning towards a combination of bad prep work,not the correct activator&or over reducing.I'm pretty sure the over reducing is a big part of it because When I had this issue in the past I just kept adding more reducer trying to get it wetter.Also I'm thinking maybe to much..I'm not going fast@all it seems when I go fast I get my worst results its hard to explain my speed Id say I'm going pretty slow overtime I speed up I get major orange peel.I know its all trial&error but these little spots are killing me!
Ok let me try to answer a few questions.Now I've gotten this effect with guns fresh out the box or old guns I clean with nason reducer.Its happened on all different panels.When I had the issue in the summer it was in the 90s.So with the same issue while cold I'm thinking temp is playing a big roll.All the panels had been sitting in the shop for months&I had heated the shop for a few hours.When I say shop I mean my home shop.Its a detached 24x36 metal building sheeted with sob&insulated with foam board.I work on my project cars&bikes down here that's all nothing exposed that shouldn't be.The building is well ventilated it has a pitched roof almost like a lean to starts@7 ft & runs to 12 I'm working I'm the 7-10 ft section&above my head is the foam board which has 1x2s securing it to the peeling that are on the other side of the foam& below the metal.This issue has happened when painting inside or out.I even used a booth for a day @ a friend of a friends&had same issue.There not really like craters as there's no hole in the middle of em. It &this is gonna sound stupid looks like if you fell asleep on the carpet&it left indentations on your skin.
