Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #55 (permalink)
Old 12-01-2012, 09:23 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
It could be the gun, the type of tip your using, the way your gun is set up...Some painters like to lean out the gun and paint slow, less runs, but sometimes less gloss.. I paint fairly fast with about 75% overlap...It depends on what works for you.
You could try adjusting the gun to get more material out, then you'll need to move faster.
