Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #62 (permalink)
Old 12-02-2012, 05:02 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Single stage as I mentioned will take a long time to set up, as far as orange peel goes, it might be, I can't see it. Also if it disappears when the sunlight hits it, it shouldn't be that bad...many urethane paints, and clears do have a texture to them...look at any new car at a dealership...The majority have orange peel. In order to get rid of orange peel, different gun set ups and techniques need to be tried as every paint is different in thickness, flow time and cure time. If you have a little orange peel and it seems to go away in the sunlight...it sounds like your major problems are solved...correct?
Ray
