Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #67 (permalink)
Old 12-02-2012, 06:07 PM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by cutthroatkid View Post
The camera was about 12 inches away but I just went back down there its orange peel.I had the gun adjusted to where I had the cigar pattern&it all seemed well bumpd up to 33psi The whole vehicle is like this now.I'm about to give up this isn't my first time ending up with bad orange peel.I only have tomorrow to finish it as I'm going out of town so I gotta figure out if I'm gonna resand the whole thing or what
Need to know what gun you are using. What is the max psi stated for the gun in the instructions. And are you setting psi with the trigger pulled? To me, it looks like something I sprayed when I had the psi set way too low.
