Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #86 (permalink)
Old 12-03-2012, 08:50 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
They do still make them and a good suggestion, when using automotive paints, viscosity cups are not used as often today as they used to be used. Manufacturer's are building the required viscosity into the material and a standard reduction and catalyzation usually give the required viscosity. Industrial paints, if the manufacturer recommends reduction, I would think some paints in the same line are thicker than others and are required to be reduced for maximum flow.
Just like golf, so much to remember.
Ray
