Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #97 (permalink)
Old 12-05-2012, 03:07 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by cutthroatkid View Post
Ok so I was just told is base doesn't peel usually but clear will. so am I going to get peel in the clear. because even if I do 6 coat of clear what is from the first coat to the 6 all of it has orange peel the net is pointless to wet sand right? also I have a buffer but I have no clue how to cut and buff
Clear Coat is a thicker product and chances are it will peel as well...Like I mentioned earlier...Why not wait until Christmas when you get your Devilbus gun...If that's a problem, then the orange peel that won't be fixed until you get proper equipment...If you where closer I'd let you borrow one of my guns but your in MO and I'm in Canada...You mentioned you had a friend that had a gun...could you borrow his?
Cutting and buffing an extended cab...the clear has to cure thoroughly before you polish and with the temperature you'd in all probability be there till Christmas anyway.
I am seriously trying to help, but, everything seems to come back to equipment.
Ray
