Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #104 (permalink)
Old 12-05-2012, 04:04 PM
John long John long is offline
Originally Posted by 69 widetrack View Post
If your tech sheet is for Single Stage, try reducing it...I think I mentioned in a previous post to reduce it between 10 and 15%.
I think all the advice 69widetrack has given you is right on. It definitely sounds like the viscosity of your paint is way to thick. You do not mention whether or not you have sufficiently reduced this paint. If it is not properly reduced you can use the best equipment money can buy and it is still not going to flow out. You are going to end up with the orange peel or dry overspray.
