Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cold weather painting&needing help
  #111 (permalink)
Old 12-05-2012, 06:20 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
To much air pressure can indirectly cause orange peel or the look of orange peel. When I say the look of orange peel it's because with more pressure you get more over spray, this over spray, because of the increased pressure is curing as it lands on the panel your painting giving you little bumps that you cover with a wet coat of clear...If you've ever felt dried over spray, would you paint over top, no, it's not smooth enough.
Hope this explains your question
The Following User Says Thank You to 69 widetrack For This Useful Post:
cutthroatkid (12-05-2012)
