Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coleman Air Tools
Old 05-30-2004, 05:26 PM
Malibucdl's Avatar
Malibucdl Malibucdl is offline
Laissez les bons temps rouler
Last journal entry: Frame Removal
Coleman Air Tools
How well built are the Coleman Powermate Air Tools? Are they reliable?
Reason I ask is, Pepboys has a deal right now for a 62 pc. Colaman air tool kit for $100.
This is what it contains:
(1) 1/2" Impact Wrench w/connector
(1) 3/8" Ratchet Wrench w/connector
(1) 1-5/8" Hammer w/connector
(1) 1/4" Die Grinder w/connector
(1) Air Duster w/connector
(1) Blow Gun w/connector
(8) 1/2" Drive Socket Set
(1) 4mm Hex Key
(1) 3" Extension Bar
(1) 3/8" to 1/2" Adapter
(1) Mini Oiler
(1) 1/4" Quick Connect Coupler
(1) Tape Sealer
(1) Oil Container
(1) Spring Retainer
(4) 125mm Round Chisels
(1) Carrying Case
(1) 1/8" Collet
(1) 1/4" Collet
(5) 1/8" Mounted Grinding Stones
(5) 1/4" Mounted Grinding Stones
(1) 1" Sanding Drum
(1) 3/4" Sanding Drum
(5) 1" Sanding Drum Sleeves
(5) 3/4" Sanding Drum Sleeves
(2) Wrench for Die Grinder
(1) Inflation Needle
(1) Rubber Tip Nozzle
(1) Safety Nozzle
(1) High-Pressure Nozzle
(1) Tapered Nozzle
(1) Dual Head Tire Chuck w/connector
(1) 1/4" M/M Connector
(1) 1/4" F/M Connector
(1) 360 Swivel Connector
Would this kit be worth buying? What are your thoughts on it?
Chris
