color difference in 2 k primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2005, 08:50 AM
I have my car in gray 2k primer and had to buy another gallon of the same 2k to spot in some places where I went down to epoxy. The problem is there is a difference in the shade of gray even though it was mixed the same and the same brand. My question is how important is the color being the same shade of gray when it comes to bc/cc? It's not a big difference in the 2 grays but enough to see where I spotted it in.
Old 05-27-2005, 11:00 AM
VWFan's Avatar
Farfegnugen
Last journal entry: logo fun!
I had a few shades of primer when I was ready to spray my base coat also. I sprayed three coats of my white base coat and I did not have any trouble with coverage being consistent. I was painting white, so I am pretty sure I would have noticed if one area was effected by the color difference. I have heard a lot of people say that the primer color does make a difference, but I could not see any in my particular project. I would venture to guess that it may depend on what color you are painting, what type of paint you are using, etc.... Hope that helps....
Old 05-27-2005, 11:25 AM
Thanks VWFAN, I was thinking that if it did show in the first coat that it may not in the 2nd or 3rd, but if it did it would be too late at that point. I don't know if white covers better or worse than other colors but it seems you would be able to see a difference if it was there. I'm just trying not to spray a sealer coat since i'm already sanded to 400 grit and almost ready to spray.
Old 05-28-2005, 09:15 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
It will be fine. A slight variation is not going to throw off the paint scheme.
Matthew
Old 05-28-2005, 09:36 PM
only time it would matter is if it was a primer used as a base for a tranparent candy paint or something. With the basecoat/clear you spray enough coats of base till you can't see the undercoat (primer) through the base anymore then clear. In fact cars are often painted with different colors, like you have a factory color, but some repair areas with say grey primer. Then you might paint the spots of primer with the basecoat first and get them somewhat covered before spraying the whole car. If you sprayed a sealer most are non sanding, so it would be sprayed just prior to the basecoat and wouldn't have to be sanded if it was applied well. But if you primered the whole body you won't need a sealer. It would only be benificial if you had a poor covering color or a primer that the base would take forever to cover, or to get the body all one color. When I use to use the yellow urethane primer at a used car dealer, would spray a sealer even if the whole body was primed because that yellow was hard to cover a lot of times.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Self Etching or Epoxy Primer Ron M Body - Exterior 14 11-30-2010 07:23 AM
2k Primer scraping off? Need help misteryu Body - Exterior 1 07-17-2004 05:55 AM
Old School - Black Primer Look - Paint Guns primerbaby Body - Exterior 11 02-06-2004 05:59 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 02:28 AM
