color of the primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2004, 07:27 AM
Rodrunner's Avatar
Dream as if you'll live 4ever
Location: Roanoke, VA. The Heart of the Blue Ridge Mountians
color of the primer
This may be a dumb Question but does the color of the primer affect the final color of the paint?
If not why are there different color primers?
Old 01-21-2004, 08:15 AM
willys36@aol.com's Avatar
Wiki Edits: 21
It absolutely does affect the color of the final paint, especially for lighter, brighter solid colors, yellow is the worst. Black and metallics are less affected.
Old 01-21-2004, 09:40 AM
nightrain_rod's Avatar
Blue Oval Finatic
What color primer should be used for a solid bright red paint job?
Nightrain
Old 01-21-2004, 09:52 AM
Wiki Edits: 21
I always use dead white sealer under my solid color paint jobs that are on the medium to light side. Seems to give it little extra brightness.
Old 01-21-2004, 10:15 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Just have the paint store tint your sealer the color you are going to paint.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 01-21-2004, 10:33 AM
Thom Laybourne's Avatar
Prep
Additional note. I like to use different color primers when doing the body work. Shoot white then gray. When sanding if the white starts to come through I know I have a high spot. If the white causes a circle it is a low spot. But I do shoot the whole car with white just before the final color. White undercoats seem to bounce the light back to the surface.
hr41pearl
Old 01-22-2004, 10:42 AM
Rodrunner's Avatar
Thanks !
I was wondering because a friend of mine was saying it didn't and I said it did.
I'M RIGHT!
I'M RIGHT!
I'M RIGHT!
Old 01-22-2004, 06:37 PM
302 Z28's Avatar
Having the paint store tint the primer the color of your base is the ticket.
Vince
Old 01-22-2004, 07:43 PM
Have Gun, Will Paint
Vince
Yap! or you can mix in some of your base with the white primer too
Old 01-22-2004, 10:01 PM
New Member
well i'm in collision repair school at my local community college and our teacher likes to use that stupid pink ppg primer. i usually use gray though
Old 01-22-2004, 11:16 PM
troy-curt's Avatar
Remember the color of the primer will not effect the color of the paint. It's the color of the sealer that can make a difference..
Troy
