Hotrodders Bulletin Board > Tech Help> Body - Exterior
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 10-13-2009, 04:50 PM
stock2mal stock2mal is offline
Color sanding 2k clear
Ok, here goes. My bumper problem is ongoing, so I am going to remove the bumper, strip it completely and respray it off the car. I did get the car based and cleared, and everything is good aside from some very slight orange peel here and there and a few MONSTER runs.
What do you guys suggest for hand sanding (I am afraid of burning through the clear if I use a buffer and I am tired of this headache of a project) in regard to taking out runs? Start with 1500, move to 2000 and then polishing compound?
Any suggestions?
You have no idea how much I appreciate your input.
  #2
Old 10-13-2009, 07:09 PM
jcclark's Avatar
jcclark jcclark is offline
The Penny Pincher
Last journal entry: Honda Civic
This stone block by Meguiars works so much better on runs than sandpaper.
It's rock hard and flat. You can wet sand the run without hitting
the surrounding clear because it's so hard and doesn't flex.
I use a 1000 grit block, it's the quickest and easiest way I've found.
After that I sand with 1500 or 2000 paper to rid the scratches from the block.
My runs disappear completely now
http://www.autogeek.net/meguiars-un...ding-block.html
Old 10-13-2009, 08:59 PM
That's awesome, I will try to locate one locally this week and give it a shot.
thanks a lot!
Old 10-14-2009, 05:35 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Old gunslinger
Wiki Edits: 11
yeah thanks JC I'm going to try one.Sounds great..
Old 10-21-2009, 05:38 PM
I picked one up and gave it a shot. I thought I was going to have to repaint my rear hatch, but I was able to take all of the runs out with this little thing. Made the job much quicker and easier.
Now I just have a few runs here and there to take out and I should be in good shape!
Old 10-21-2009, 05:43 PM
Old gunslinger
Wiki Edits: 11
HEY I'm sold I'll have to get one the next time I get a run.....It might take a while though......lol.....just kidding.....
Old 10-21-2009, 05:50 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Question: How have you guys heard Meguiars pronounced? I heard a guy on the radio the other day say Megears.
Vince
Old 10-21-2009, 05:56 PM
Old gunslinger
Wiki Edits: 11
Mick why ers
Old 10-21-2009, 06:00 PM
302 Z28's Avatar
That is the way I have always herd it pronounced, when I heard Megears I went "what is he talking about". I almost called the radio station, but I only heard the commercial once, they must have pulled it real quick.
Vince
Old 10-21-2009, 06:27 PM
Same as in Jerry Maguire, except without the annoying little kid and ugly smooshed face chick.
Old 10-21-2009, 08:40 PM
Old gunslinger
Wiki Edits: 11
Wit a wee bita scottis accent ladd
Old 10-21-2009, 11:39 PM
88_mopar's Avatar
88_mopar 88_mopar is offline
Another method i use at work is to take a brand new razor blade and sort of drag it along the run to level it with the rest of the clear. Wet sand with 1500 to feather the peel out then 3000 on a DA before buffing. Our painter sucks so i get alot of practice.
Old 10-22-2009, 01:35 AM
rcrobbins's Avatar
rcrobbins rcrobbins is offline
Robbins Racing
Another useful tip I figured out on my own; instead of using a spray bottle, grab an old HVLP gun, ~10psi, closed fan, open fluid. Now I use the bottles to hold my warm refill water and my pointer finger loves me for it I'm sure people have figured that trick out, but I've never heard of someone doing it. Other than that, I use my tripod guitar stand at my side to hold the gun by the cup in the "U" that would cradle the guitar neck. I just spray, sand, squeegee, then use slight trigger pull on the gun to quickly blow the moisture off and see where you're at on the orange peel or run in this case. Hopefully some poor guy will thank me for saving his fingers
Old 10-22-2009, 07:53 AM
Old gunslinger
Wiki Edits: 11
WOW!!! thats using your head I'm tired of buying pump bottles they break when you drop them...great idea...88 MOPAR its a beach I know, but its all part of paying the dues... One day when that painter gets drunk and dont show up you'll be able to save the day, so practice anywhere you can every chance you get......and when the boss sees you paint better than the painter ...your in....Worked for me....
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Color sanding 2k clear"
ThreadThread StarterForumRepliesLast Post
Compressor-less all aerosol repair review.MARTINSRBody - Exterior605-15-2009 08:43 AM
SPI primer and clear, a product review, and a "how not to"lowROLLERchevyBody - Exterior2612-21-2006 07:40 PM
2K Aerosol epoxy., urethane primers AND clears!!MARTINSRBody - Exterior811-10-2006 08:45 PM
New Paint, Clear Scratches real easy??syclone477Body - Exterior1103-20-2005 09:08 PM
Question about epoxy over 2kmisteryuBody - Exterior408-31-2004 05:59 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
