Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - color sanding & buffing help needed
Old 08-19-2006, 03:50 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Block with 1000, 1500, 2000 then go over it with an Abralon 4000 DA pad. It will almost shine when you are through with the Abralon 4000 DA pad. If you still see sand scratches after buffing you are not doing enough finer grit sanding. After buffing with wool pad you can then work it with a Porter Cable orbital polisher with some final glaze. The Porter Cable polisher is not as aggressive as the buffer and you can work it longer.
Vince
