Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - color sanding & buffing help needed
Old 08-19-2006, 04:09 PM
colormecrazy's Avatar
colormecrazy colormecrazy is offline
Paintshop Dog
Originally Posted by 302/Z28
Block with 1000, 1500, 2000 then go over it with an Abralon 4000 DA pad. It will almost shine when you are through with the Abralon 4000 DA pad. If you still see sand scratches after buffing you are not doing enough finer grit sanding. After buffing with wool pad you can then work it with a Porter Cable orbital polisher with some final glaze. The Porter Cable polisher is not as aggressive as the buffer and you can work it longer.
Vince
Ah yes, the Abralon, had to let that secret out, didn't you!
No just kidding, my boss thinks it's too expensive?
