columbia 2 speed rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2002, 08:11 PM
Post columbia 2 speed rear end
I have one of these that has been "resting" for 35 years. What should I do to check it out & use it in a flathead rod I'm building. What kind of power can they take & if I decided to sell it, what's it worth?
Thanks
Old 10-14-2002, 04:07 PM
woodz428's Avatar
Troll Hunter
Post
They are pretty stout, if your using it behind a not to strong flathead. Do the typical drain the rear and check for metal, replace the seals and add a modern rearend lube and you should be good to go. They seem to be pretty popular and would probably bring some large money in good shape.
Old 10-15-2002, 07:05 AM
Biggarmike's Avatar
Chief Procrastinator
Post
If you decide to part with it, drop me a line. I'm looking for one for my '36 Lincoln.
