column - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2012, 06:53 PM
column
does anybody know, of a donar cars steering column that will work in 55 belair without buying aftermarket
Old 02-06-2012, 01:04 PM
Not without modification. If you can find a GM column out of a motor home, many of them came with no shifter, or key. Same as a 70s van column, but no shifter. Either one will need modification. If you are doing power steering, the stock column can be used with modification.
GM column ? evolvo Electrical 11 03-06-2013 12:11 PM
Covert maunal column change to auto column change devious Transmission - Rearend 2 06-04-2007 02:10 PM
column drop for a 2.5" diameter column bet on black Suspension - Brakes - Steering 3 04-05-2007 01:03 PM
Can't get my column out Stroker56 Suspension - Brakes - Steering 4 02-27-2005 06:21 PM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 07:56 PM
