Column Confusion 1980's Chevy Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2007, 01:54 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Hey Y'all
I'm Working on a 1984 Chevy Replacing a Theft /Recovery steering column.
Now removal & installation have been a snap but I had to install the cruise control wires which was tough but I made it .
My problem is I can't seem to get the steering wheel to line up! no matter what I do its about 1/4 turn off
There is no room to play @ the rag joint or the center shaft bolt & with the turn single cam there is only 1 way it can go. I'm stumped .
I did not drive the truck so it might have been wacked out to start. it was a complete mess nothing worked I don't know how the guy drove the thing .
Could this be a Tie rod connecting sleeve adjustment ?
I'm about to put the busted turn signal cam back in & tell him NO HORN!! use finger.
LOL
I'm going nuckin futz here!
Thanks
R
ID:	20669   Click image for larger version
ID:	20670   Click image for larger version
ID:	20671   Click image for larger version
ID:	20672   Click image for larger version
"SlowRide66"
"Illegitimis non carborundum"
Old 04-22-2007, 02:19 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
since the steering wheel will basicly only go on one way(because of the horn wiring into the steering wheel) I would say it needs a "tie rod connecting sleeve adjustment", the only other thing i could think of would be the
front end alignment.....joe
Old 04-22-2007, 03:19 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
A front end shop typically turns the steering wheels straight, locks it down with some device, then aligns the wheels to that. I have seen some old fords that were way off and that is all it took to fix them. You had to hold the wheel turned going down a straight road.
Old 04-22-2007, 04:00 PM
Rob Keller's Avatar
Wiki Edits: 38
Thanks guys I guess it has been whacked for a while .
i will question the owner some more tomorrow.
I did not take the "tie rod" thing into account until I had removed all the connections a few times looking for a reasonable adjustment& got inside & started posting this question.
I know he needs some front end work just from looking @ the tires, but I doubt he will do it he only uses this thing a few times a year to haul water Mellon's.
I guess I could put a horn button externally
This poor truck should be retired. it makes mine look mint
LOL
I could use lots of parts off it like that big juicy 454!!!MMmm Yummy
Thanks Soo Much!!!
R
"SlowRide66"
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
53 chevy panel truck huligar General Rodding Tech 12 04-27-2006 03:53 AM
1951 Chevy Truck chevblazk5 Suspension - Brakes - Steering 3 01-26-2006 08:27 PM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 03:31 PM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 01:16 AM
