column drop for a 2.5" diameter column - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2007, 07:58 PM
bet on black's Avatar
hotrodder 4 life
i am looking for a column drop for a 2.5" diameter column.
the column is out of a 77 nova, i am putting it in a 59 chevy truck. the diameter where the drop would mount to the column is 2.5"
anybody know where to find one?
thanks
Old 04-04-2007, 10:01 AM
AllSteel34's Avatar
I usually fabricate my own and weld it to the column.
Chris
Old 04-05-2007, 08:56 AM
powerrodsmike's Avatar
Wiki Edits: 161
Buy a 2 3/8" and if it truly does not fit your column., bore it out the extra .125".
It's a simple lunch money job for any kind of machine shop if you don't have the equipment or ability.
I've hogged them out that far with a drill and rotary file, then cleaned it up with a barrel sander.
Later, mikey
BE different....ACT normal.
Old 04-05-2007, 12:03 PM
hotrodder 4 life
ok where do i find one of those, the largest i can find is 2.0"
edit, nevermind i found one here, i will try it. thanks guys!
http://www.rjays.com/Billet_Spec/billet-columns-01.htm
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
GM Column Wiring - Help Please Centerline Electrical 1 04-15-2005 05:29 PM
